How the Hall do u fit the clips to the arms and jets theres 2 2 different clips per side .Anybody got a pic
Thanks mark
Thanks mark
Slide the jet bar into one clip a bit too far, then slide back into the other clip - don't try to force themHow the Hall do u fit the clips to the arms and jets theres 2 2 different clips per side .Anybody got a pic
Thanks mark
These clips are for holding the pipe/hose to the wiper arm. Have a look on the sides of the wiper arm and all should be revealed.Thanks Danny the ones on the pack are different to that .You wouldn't mind bit I only bought them for 2 clips .
The ones in your pic are the same as the ones I have on driver side p side is cabled tied on
I bought and fitted a pair of those and rapidly went off them, they didn't last long and the blade looked a little skinny without the spray blade.I sent these back in the end .Sick of buying stuff that's not what it seems .Anway will go the Wipex route
I notice that Wipex do on the arm jets .Looks like a fit and forget solution ,also leaves u free to fit any blades you want.
Anybody fitted these ? And has a pick of them fitted
Must admit they ain't cheap though £17 for a pair of washer jets ! The originals are cheaper
Thanks Mark
Have u got a pic ? Must admit u cant beat the original ideal for getting water on the screenI bought and fitted a pair of those and rapidly went off them, they didn't last long and the blade looked a little skinny without the spray blade.
The car is in at the garage at the mo unfortunately.Have u got a pic ? Must admit u cant beat the original ideal for getting water on the screen
I have just bought new oem wiper blades and the oem spray bars.Sorry didn't view your picture correctly, was a bit early in the morning when replied. In your picture you have 1 of each clip shown for each wiper arm. Please see picture for explanation.
