S
My gearbox has started to make a slight whine.
I plan on checking the oil level at the weekend.
If the level is ok(i didn,t check it after the clutch was fitted)what can i do to make it quieter e.g.are any of the additives you see advertised any good.
Regards
Shug
J
Discussion Starter #2
a thicker oil might do it...but it will be harder to change gear when cold.
F
there is an excellent gear box oil called tutela,put some into my last 8 valve,which had 137000 mls.its expensive though.
alan.
