1 - 9 of 9 Posts
Hi does anyone know where the gearbox oil refiller is on my 156 jts? and if it it linked to the drive shafts i have a slight leak on one of them and would like to check the levels - thanks R
Yes, it will be linked to the driveshafts .. the same oil lubricates the gearbox and differential where the shafts drive off.
The oil level indicator is simple ... take out the filler plug and check by inserting your small finger(!) and judge how much oil is there. Or, simply top up slowly and any excess will start to run out. Gearbox oil is pretty smelly stuff so make sure you have plenty of paper, paper-towels, rags underneath to catch any excess. You need to have the car on flat, level ground too.
V6 boxes are more advanced and come with a dipstick!!
0
AFAIK face the car from the front, it's to the right & down between the bulkhead & the 'box (fill through dipstick hole)
0
Am due to change mine & am pretty 'hands on' - I will confirm soon (& take pics) unless you are desperate :D
AO Car Of The Year Winner 2015
1 - 9 of 9 Posts
