Just done a gearbox oil change on my 1.9jtd with the 6 speed manual box following an article on here. What was odd though is that even with the back end jacked up a little I still only got about 1.2 litres of oil out. So I added 1.5l as I read that it works better with a little bit more. I'm a bit bothered that there was not much oil taken out but I read that some will stay in the box. Is there a 'level' hole though so I check that the box wasn't just low on oil initially?
It hasn't done much though. Still seems a bit 'notchy' and 2nd to 3rd although doesn't grate it does seem a little rougher than the other gears. It's almost as if you can feel the gears meshing when going into 3rd.
