Hello,
Been a while since I've had to start a thread for answers on a problem..
My gear change has been a bit notchy and floppy since i've had the car, but yesterday it suddenly got a bit worse..
It now feels notchy going into all gears, especially between 3rd & 4th where it makes knocking noise around the selector gator when in the neutral position.
Any idea on what needs replaced, I know there are many threads on the subject suggesting different causes. Will the following kit do the trick? Gear Linkage Bushes 'Top Hat' - Autolusso New Parts Shop and is it easy enough to fit?
Thanks in advance
Thanks for the reply.
The gear lever centres just fine - just feels looser and theres a bit of resistance and a sort of clicking sound from the selector when engaging the gears.
Any other things to be replacing when in-about the selector? Also, are there any particular techniques for getting at the linkage, would like to avoid damaging the interior with my ham-fisted ways.
how much of a job to replace these? is it an inside the car job or more mechanical? any help or advise as i could do with relacing mine to tighten up the gears
scott.
To replace the whole cable? Exhaust and subframe off... not quite as easy as you'd like.
I need a new clip thingy on the end of one of mine.. on the to do list.
