Hi all
I've got a alfa 147 2.0 manual with 122000km on the clock . I have been getting a lot of play on gear lever which is making it difficult to change gear. If any one has experianced this pls let me know what parts you have changed and cost?
Regards Giulio
Does your gear stick have a lot of 'wobble'? Especially in neutral?
Is this the white casing under the gear knob gator? Seems common for them to crack, i've had this on both Alfa's. Only problem is you need to remove it from underneath which means exhaust off. I'm trying to find a guide someone posted.
If you're new to the car, you'll get used to the gears.
Found it; http://forum.alfa156.net/forum/forum_posts.asp?TID=48734
