Hi all i want to replace my saggy gaitors with lovely leather ones i ve found on fleabay any tips on removal? easy? tools required? etc!
many thanks
Alfa Mito, 2010, 1.4NA, 6-speed
On the 156, the gear lever gaiter is held in at the bottom by a springy frame and just clips into the console. At the top its held by a large pop-stud. Similar on the handbrake. Not sure whrther the 147 is different .. probably is knowing Alfa!
ebay ones will probably be less advanced .. the one I bought for my Pug used a cable tie to hold it to the gear knob and I had to cut small holes in the leather to fit the frame!
Hi thanks for that will have a fiddle ebay listin says you use your existing frame for the new gaitors so we'll see! cheers for the tip:cool:
