Almost certainly the 'T' shaped non return valve. You will need to take the wiper arms off and then remove the black plastic scuttle panels to access this.
+1 - assuming the washer motor is running!
Prise off the top of the non-return valve (be careful not to lose the small spring and rubber seal) and clean!
You can just about get to the valve without taking off the wiper arms, if you remove the screws holding in the scuttle panels
Another issue might be that the washer bars are blocked
Rich ;)
First off try the Filter in the Washer Bottle, blocked with gunge is a VERY common problem.
Just pull off the Washer Motor and then lift out the " Top Hat " Filter you will see underneath, odds on that will be the problem.
( I'm assuming that the Washer Pump Motor is running....... )
