Hi Everyone
I have just brought a 147 (x reg) and need to get to the fuse box in the cabin to replace the cigar lighter fuse.
Simple question... can anyone tell me where the fuse box is... I'm guessing it should be under the steering wheel but I can't see it.
Also I am getting a cluncking / knocking noise from the passenger side front wheel area when I go over bumps... recent MOT advice mentioned: Offside front suspensionhas slight play in a upper suspension ball joint.
Could this be what is causing the noise and is it expensive to fix?
Thanks all... great site.
J
I think mine (2004) is under the steering wheel area. You should see 2 screws at the top of the lower cover, then it just swings down towards the pedals, and your fuses appear.
Well ,,,,u should unscrew the 2 bolts under the steering wheel and open the the plastic cover which will unveal the fuse box
the cig lighter fuse is in the 2nd row from the buttom the one in the right tagged with 20 Amp .left wheel drive
cheers
Hi All
i am having an issue with my alfa 147 2003
sometimes it will not start leave it an hour and away she goes
i have read the forum about loose fuse box connections
so i have unplugged the the multi plugs and re-plugged them in to see if this cures the problem. no joy
the problem i have now is no rear indicators no rear lights no interior lights the central locking locks then unlocks itself no fuel gauge
the mileage display just keeps flashing the electric windows don't work
i have unplugged the multi plugs and checked that they are connect ok i have also checked all the fuses around the car no blown
has anyone any idea
Murray
