B
fuel pump dont prime when ignition comes on i have tested as much as i can find to test.
as far as i can tell i have no live from the ignition to the relay i have tryed to trace back to the ignition but cant seem to find my way can anyone point me in the right direction.
there dont seem to be a break in the ciruit any sugestions wellcome.
J
Discussion Starter #2
you could just take the easy option and run another live feed from the switch to the relay.
B
i have thought of that but im not shure if that would flood it what problems could that give me if none i will do it
J
as long as you just go from the ignition to the relay(as the original wire did)it should just work as normal.
B
i miss read what that i thought you ment to the pump im not shure where to feed the live to the relay would it prime and stop as normal if i leave ignition on without starting it
B
cool can you point it out to me a bit better im not that good at ellectrics
J
if you find the main live into the relay..make up a new wire from the ignition switch to the relay....it should purge and work as normal.
B
thanks jimybob i dident think of that i will see if i can find it i am smileing again mate
