21 - 29 of 29 Posts
Discussion Starter #21
Well....yes & no. I went out to buy a new battery (as I was jumping the car from my Volvo), installed the new battery and it now just sputters....doesnt really fire.
So, all I can rule out is the fuel pump. there may be a clog in the fuel line (as, using the glass bottle method aforementioned, the carbs sucked in about 1/2 litre) as it’s now reconnected and/or the carbs need tuning.
So I’m very close and greatly encouraged that the engine still runs smoothly...when it has fuel :)
Discussion Starter #24
Ok...here we go again.
After figuring out the fuel issue with your help, I hosed down the engine bay (cuz it WAS filthy) and left the car to dry....for 2 weeks...whilst I went off on holiday (Ironically to Italy).
It now doesnt start.....again....argh!
One interesting thing - the coil is super hot. I had disconnected the battery whilst I was away to prevent drainage and to let the engine bay dry out well.
Reconnected the battery and tried to start. didn’t start to left it for a couple of hours. Came back and that is when I realised the coil is super hot. So I disconnected it and will try again tomorrow. But why would the coil be super hot? Some type of short?
The coil will get warm, quite warm, but did it get hot with the ignition off?
Discussion Starter #26
Ah, no, the ignition was on (to prevent the anti-theft from kicking in - trying to troubleshoot lol).
so probably normal them.
will check back in tomorrow
Discussion Starter #27
Hi guys - so my car won’t start. I need help. As a reminder:
  • I thought there was a fuel pump problem initially - with your help I got it started about 2 weeks ago
  • before leaving on holiday, I hosed down the (cold) engine compartment - it was filthy as the car sat for 3 years without running (i know, i know :)
  • it didn’t start after but I figured I had soaked something (like the starter coil / etc). so, I figured it would dry out over my 2 week holiday
  • I still have the hand pump connected so pumped fuel to the fuel pump today
  • so, no fuel issue
  • it won’t start. I reseated all plugs and the wires to the coil
any ideas on what to check?
You've probably burnt out the coil. You should never leave the ignition on for more than a minute or so, as that will be the result.
21 - 29 of 29 Posts
