The short rubber return line hose from the metal fuel line to the fuel rail is leaking. Right at the front firewall.
From what I can tell it is stamped 7.2MM. This seems to be impossible to find.
Will 5/16 (8MM) work or be too loose?
It looks like one of the lines has already been replaced.
Also how do you get those bottle cap type clamps off? Just pry with a screw driver?
I can post a pic if this doesn't make sense.
