What could cause a car to lose 10% - 15% of its fuel economy?
I'm asking for someone else, the big blue Skoda is working just fine :tut:
Yeah right, that old chesnut faffyWhat could cause a car to lose 10% - 15% of its fuel economy?
Doesn't feel like the brakes are sticking, there is a high pitch squeal at low speed sometimes which disappears if you press on the brake pedal or wobble the steering wheel a bit.Tyre pressures?
****ty combined hand/foot brake calipers sticking?
I haven't seen a dash mpg reading but I generally ignore those now anyway, this is a calculation from brim to brim fill ups. Every other time I've checked it has returned between 37 and 39 mpg average, the last couple of times I checked its been hovering around 32 mpg. I tried the tyre pressures, all dead on spec and I know they're checked at least monthly.If it's the display showing lower MPG, does that tally with what's actually being used?
Not a diseasal :smash:DPF cleaning?
You remember the water in the boot thread ?Yeah right, that old chesnut faffy
My 'mate' has this boil on his old chap :lol:
It's being weighed down by its own dullness.You remember the water in the boot thread ?
Same car, little 1.4 Toyota Corolla.![]()
Lower octane fuel, or more ethanol in the fuel. Or both... Lower temperatures, both external or inside the engine transmission. The latter also influences tyre pressures.What could cause a car to lose 10% - 15% of its fuel economy?
I was just a guess. MPG is something which painfully felt by arse than drive conditions are not in all.I have a mix of roads BG, some 50Mph (80Kph) and some 30 Mph (50Kph). Usually this car does between 36Mpg and 39Mpg (6.5 l/100km to 6.0 l/100km). The roads have not changed, the driver has not changed as far as I know, so it has to be mechanical problem I think?
