Is there consumption difference between N & D modes if you drive same way or style..
I couldnt test it.. Anybody test the difference ?
The differences are a) system modes change this way in order D / N / A;
VDC; SPORT / SOPT / CONTROL
Q2; ON / OFF / OFF
STEERING; SPORT / SOFT / SOFT
OVERBOOST ON / OFF / OFF
POWER; SPORT / SOFT / SOFT
b) within these modes power is delivered more gradual in "N" and even more so in "A" mode to help with traction and help avoid ASR (anti slip) intervention.
I have a tct. Is it that much of a difference? I've only just got the car so I'm still adjusting.
Normal is so sluggish in my car. Maybe it's the tct and normal.
Especially with TCT you will note that in auto mode the gear changes up to top gear as soon as possible to achieve maximum fuel economy. That is how it is done, driving in taller gears as soon as possible. The downside is what people call "sluggish" performance.
If you have a manual (non TCT) you control the changes but there is a "shift" light on dash (only in "N" mode) to advise you to change, early in rev range (making use of peak torque) to try and match/achieve the TCT auto mode i.e. Max fuel economy set auto shifts. That is why the TCT has a certified better fuel economy than the manual (non TCT). Indeed almost all sequential dual clutch (all brands of car) have better fuel economy than their manual equivalent (the exceptions being only full performance only sport models).
However, as with non TCT, if you put the lever in to manual over ride in the TCT you can hold the gear longer and what was "sluggish" is no longer so "sluggish". But fuel economy suffers.
In "D" mode you will be using overboost, another 20nm torque and all the MA can muster under the factory spec map and whether you use auto TCT, manual non TCT or TCT in over ride you will d=find it very swift indeed. But definitely not the best fuel economy.
Hope this helps. BTW my comments are with experience on non diesel Alfa vehicles and 2.0 diesel VW Passat as an example.
PS Forget plug in tune box claims of "better fuel economy" because all you will get is more power at the cost of higher fuel usage.
