My 2.4 JTD MJ SW front wheels had laser front tracking done 2 months ago and to check the balance of the front wheels. All reset as per Alfa Recomendations.
Both my front wheels seem out again, when I self centre the steering wheel. Would this be failing track rod arms or something else?
The rear tracking needs setting too, did they do that?
Remember to set the front to 0mm toe (ie parallel), some places still have the old settings).
Set the rear to 3mm toe-in.
You need all four checked at the same time to ensure they are all pointing in the correct direction.
Yes David they did that with rear wheels and they were bang on correct. Fronts set at 0mm, but 3 months on OSF is out.
