I've been trying to solve an annoying vibration which only happens when taking a right hand bend and under load. Its more noticable going around a roundabout and if you accelerate the vibration is very noticable and gearstick wobbles and if you let your foot off the accelerator it stops vibrating. Its just gone thru its mot and it needed a cv joint on the left side and wishbone on drivers side. I got the mechanic to look at it and he checked all joints and mounts and could'nt find anything wrong. I rang another mechanic ( alfa specialist) and explained the problem and he said that it could be one of the wishbones. He said there are 2 wishbones lower and upper at the front. I've checked on the web etc and i can't find any reference to there being 2 wishbones on each side at the front. Maybe he meant the rear but i don't think that the problem is coming front the rear as the vibration seems to be coming from the front.
rgds
rgds
