Just thought i would add an image of the brakes as i changed them when i did the front suspension which included Lower wishbones, ARB Drop links, upperwishbone POWERFLEX bushes, EBC Green stuff pads and EBC grooved and dimpled disks, and a new drivers front wheel bearing... oh and sun burn...
Going over speed bumps has never been so enjoyable, it was a good long days work not including the bearing of which unless you have a bearing press would not recommend you do as a diy job... As when you press the old one off the outer race stays on the hub flange and you have to grind it off... this also goes for the rear...
