1 - 9 of 9 Posts
looking at the parts CD, the front struts for the V6 and 16v widebodies are the same, but what about the springs. Again, although the part numbers are different it does list them in the shared parts bit (unless I mis-read it). Also they look the same thickness so unless they are longer they should be the same
Does anyone know for sure if the V6 springs are the same rate as 2.0 16v, or are they higher lbs for the for the extra weight ?
Thanks....
Discussion Starter · #2 ·
They are different (not checked CD tho). The V6 springs are shared with the TD model.
wrinx
Mmm, just checked the parts CD and you're right Tim........!
Perhaps it's only aftermarket springs then? My Eibachs are definately for the V6 and TD only. Other sping manufacturers do the same split so it must just be OE gear.
wrinx
On the subject of what fits what..
There appears to be a lot of parts on the FIAT TIPO that look the same :confused:
ie Front suspension,rear axle,front foglights,wiper arms and linkages,indicator stalk
Does anyone know if they are the same may be another source for bits wink
There should be quite a few bits that swap straight over as they share the Tipo/Tempra platform, dunno which bits tho :rolleyes: My parts CD doesn't want to include FIAT!
wrinx
Discussion Starter · #6 ·
Just in case anyone read this and ever needs to buy a second hand strut, my early 16v struts are slightly different to the V6, and the V6 springs are thicker coil by 1mm.....
Discussion Starter · #7 ·
It makes sense that the V6 and TD have stiffer springs because these two engines are considerably heavier than the 4 cylinder petrol ones.
I can't imagine that Eibachs are the only ones that do this - the standard ones must also be different part numbers - as Tim says.
Ian
Jus to confuse things some spring manufacturers list the same spring for all models and some list different for v6 and diesel so maybe no one really knows :confused:
Confused !!!!!!!!! well i am so i,ll shut up :confused:
1 - 9 of 9 Posts
