front koni/spax/leda inserts wanted for 33 struts
6.8K views 65 replies 17 participants last post by  oui4824
#1 ·
as the title says, i need some inserts for my 33 struts for the impending conversion to coilovers on the sud.
the koni sport type or similar, not the standard issue inserts.
had a quote from GAZ which tbh isn't too bad considering what they would do (no size they do that suits the strut casing) but if anyone has some knocking about in good order or knows where they can be bought for reasonable cash then please point me where :thumbs:
#2 ·
Kev
Spax still done some for my sud but now you have to buy them as a shock and lowered spring pack for approx ÂŁ395.
They were't the right ones but I ended up sending them the complete strut and they made them up for no extra.
If they don't stock 33's maybe they will offer this service??
Harvey
#4 ·
no use mate i'm afraid. i'm going to be using 2.25" coilover type springs, much much stiffer than any lowering spring kit
koni insert kit part no 86-2448sport, these are stated as to suit boge-federbeine manufactured strut and are yellow inserts. I work for a scottish motor factor and i think Camberley Auto Factors are Koni agents, however, they may be a motor trade only supplier.
Hope thats of some help to you, im assuming you're in england of course..
yes, they are ones i've been pointed to but at about ÂŁ150 each plus the bits & bobs i need to buy no do the coilover conversions then the numbers don't stack up against just letting GAZ do the work.
be nice if someone had a souce that got them a lot cheaper....or decent used ones...
#3 ·
#6 ·
can't see why not john. think the casings are the same diameter, around 40mm I.D.?
they the ones with the lug on the bottom to allow the insert to be bolted from underneath?
in good enough order for my track car?
pm me a price please mate :thumbs:
#11 ·
Thanks Kev.
Got the e-mail.
Just need to get my car sorted now and I will be able to see how badly damaged the funds are :cry:
Another company who I have heard will do something similar is AVO. Might be worth contacting them?
Many thanks rsfruitbat
#14 ·
mate, the lowered springs like fitted to standard struts are way WAY too soft.
complete waste of time using them on track
know rodger used intrax, very good quality but at a cost. which i can't do :(
the GAZ offer is great, for what they would do. struts ready to bolt on the car for under ÂŁ600 but again, money is tight :(
#18 ·
hi liam.
i have all the stuff from the 16V 33 at the front, sprint axle at the rear.
would be interested to know what front legs you have, guessing they have been converted to 2.25" springs already if running faulkners springs?
rears at the moment i'm not too sure what to do with. some koni type shocks would be handy i guess, the springs on at the moment are class F or C ones but my shocks are standard road ones. have got a plan for that end though if needs be.
can you let me know what you have for the front though please mate? price etc :thumbs:
#19 ·
Kev, are you doing the coil overs so you can adjust for road and then stiffen for track?
The AHM springs I had on my 33 racer with konis in std struts were very hard and it handled very well, but no way could it be driven off the track so assume that set up is no good for you?
#20 ·
not going to be road car mate, not for a few years at least anyway.
was doing the 2.25" coilover conversion mainly so i can have the flexibility to find a spring rate to suit the car and me. at the moment it's way too soft at the front, both in spring rate & shock damping
you have anything for sale?
#21 ·
I don't have anything for sale, sorry.
However should someone have some ex class F/D shocks and springs don't discount them.
The yellow konis I had were revalved to suit the lowering of the car and the AHM Springs were said to be 850lbs on the rear and 650lb fronts. I bought them off eBay so never knew for sure, but on the 33 it handled excellent. The sud has softer brunswick springs (650lb rear and 450lb fronts if I remember rightly). The sud under steered, the 33 over steered. I much preferred the stiffer springs so will look to stiffen the sud springs.
AHM might still do the springs?
The sud s3 insert is the same as a 33 s1 insert so if you come across some sud konis and can find some s1 33 struts then that would work.
#24 ·
Our production race car springs are 750 rear 450 front :)
I think i have a set of the old type koni inserts the larger dia
but i have no idea if they are any good ? youe welcome to them
If you want to go coil over
just convert any strut you can get inserts for :)
mod the strut to take late inserts
buy the coil over sleeves from say Comp Brake and make reducer sleeves to suit
your strut and
Cut off the top of the strut ie the bearing housing
then make you sleeve so its the correct length to take the koni
insert
make the sleeve so the id of the top sec is correct for the
koni to pull into
then Tig weld this to the strut
then shorten the threaded sleeve to suit and tig the theaded sleeve on top job done
If you want to fit a longer thead sleeve
remove the steering arms and refit upside down to give more room :)
lot of work tho :)
#25 ·
.........just about to send them to GAZ for them to convert.......
had given up the idea of doing the struts myself due to the cost of new inserts + the coilover kit, springs, top mount conversion etc managed to get not that far short of what GAZ would charge me to convert my struts into coilovers using their own top adjustable insert...
but, if you have some inserts that would suit the boge type 33 legs?? are they the ones that bolt to the bottom of the casing like old sud ones used to? would be keen on taking them off your hands to do the conversion myself..please could you let me know asap before i send mine to GAZ and spend money i could do without spending!!
interseting about the spring rates though. i was under the impression from talking to others that the fronts would be about 600 and rear about 450.
plenty of talk of late to contradict that, including now your own views.
more than happy to take advice from anywhere i can get it. i don't mind oversteer, lift off preferably for when it's needed (harking back to my rally days), but hate understeer. so guess that a firmer rear end would help that?
#27 ·
would rather a little less than we had that day though mate :lol:
logically thinking back to that though, we had stiff race springs (class F or C, from the colin wing car) and standard front 16V springs due to the issues with trying to get the wing ones fitted safely.
i did think on that morning that oversteer might be in order :rolleyes: :lol:
so a stiffer rear than front may be in order :confused:
know i get confused easily and forget what folks tell me but think that bryan told me the other way round, front stiffer than rear :confused:
#28 ·
Just the way I have the springs Kev, slightly softer on the rear - their only purpose is to maintain ride height. My rear dampers are valved specifically by Bilstein and I use a rear anti anti-roll bar - likewise a arb on the front. Weight is 720kg - not much of it on the rear!
The car is very balanced and lift off oversteer is available (it oversteers until the rear tyres are warm).
#29 ·
well, change of plans again.
i had the struts all parcelled up to send to GAZ for them to make new legs up similar to how ade suggested. as he says, it is a lot of work so unsurpsingly it didn't come cheap. but having said that it wasn't that bad for what they would be doing.
so now i've managed to find some inserts that should fit, as long as my measurements are correct :rolleyes:
koni sport ones, but not the alfa 33 or sud ones.
fingers crossed they are just the job at less than half the price of new 33 ones :cool:
#36 ·
yes, the clue was in my brakes...
they're nissan inserts. from a B13 sunny apparently :rolleyes:
i just searched for some that fitted the list of things needed.
so they have a threaded bottom fitting so they can be bolted to the bottom of my casings.
they have a diameter that will allow them to fit inside my casings.
they should sit about 30mm short of the top of the casing where i have cut the bearing carrier so won't be any issues with bottoming out with shorter springs with the lower ride height.
once i know they fit ok i will try and find more info about applications if others want to do the same, in particular when using lowering springs as there's a limit on how low you can go with standard height shocks before bottoming them out
#37 ·
Sunny?
Doh!
i was going to be brave and suggest you may have found a crafty stash of cherry europe stuff, curiously similar to what you needed! ha ha!
glad i didn't now! :D
i tell you what though mate, good find that, and if they work out, i can see your postman getting slightly annoyed at the heavy packages you'll be sent from several other members wanting the same!
good luck....
