drivers side front indicator is full of condensation so am going to drill a hole in it to remove some moisture...how do you remove it from bumper?
Has anyone had this prob and how was it remedied?
thanks
peter
you have to remove the bumper
5 Torx30s bottom
4 torx 30 at top, unde rthe 2 small grilsl which are helding by 4 + head screws + tnhe centre parts by 2 + screws.
then remove both wheels & 2 + screws form wheel arch
then remove 5 more Torx 30 screws....
bumper will come off
then 2 10mm nuts & apop out clip will remove the headlight.
Jeepers...just to check its the indicator not headlight, just in case you misread my post as your response mentions headlight.
peter
