On my 1.6L, 145, there is a vertical front-end vibration at about 110kph. The front tyres are new and balanced. When this vibration occurs, the steering is rock solid, no shaking. Could this be a universal joint (or both) that has worn? I cannot think of much else that could cause this. Any member suffered the same thing? Any advice welcomed.
Thanks.
I've had the same but not on an Alfa.
The inner UJs produce this vibration which is bad at a particular speed.
Figuring out which side of the gearbox it is might be a challenge.
On other cars I've looked for a split rubber boot around the UJ which is often the cause of the failure.
The outer UJs are much easier to diagnose as you just need to steer round a corner to hear them graunching.
Wheels on car Dynamic Balance? If so,ok-- Geometry ? Camber/Castor/KPI. Chassis alignment? Drop test,failing contemporary laser checking facilities. Drive shafts, tried the old hose clip opposition method? Rear wheels/tyres fitted on front.Worn oscillation dampers/suspension/steering/ mountings/joints? Tyres may still be suspect, in spite of being new. Few more ideas out there Guys, to put this old Foggie in his place?
.....or the combination of CV joints and engine mountings......
On high mileage cars I sometimes think I can detect powertrain oscillation driven by driveshaft rotation.
