1 - 2 of 2 Posts
Right, losing the will to live with this issue now. I have an annoying rattle on the front left corner of my Ti. It's showing itself mostly at low speed on flat uneven ground. I have a rattling sound like something is loose on the suspension front left, but everything looks OK.... I've now replaced the upper suspension arm, outer tie rod and arb droplinks both side. Still persists!! I'm now thinking lower wishbone as not much left to try. Anyone had a worn lower wishbone, and what were your symptoms? Thanks
4
Yep, I had the same issue and it turned out to be a lower left ball joint. They come as part of the complete arm and are a complete git to change. Best of luck.
1 - 2 of 2 Posts
