I have a 'unusual' knocking from the front end, sounds like drivers front wheel area mostly.
It's a strange sound, like a metallic knocking. Almost like an undertray rattle (it's not that!).
Had the car up on a ramp yesterday to check over, didn't find anything too major just a number of small issues but didn't solve it:
-Sub-frame bolts slightly loose
-tiny bit of play in offside upper suspension arm (powerflex bushes), but nothing bad
-rear transverse arm bolt found slackened right off!
-bit of play in track rod ends - will be changed next week
-play in front drop links - fitted Meyle ones today - noise still there
-Wheel bearings have no play
-ARB (Eibach) bushes 'look' ok and mounting bolts tight
The knock is not necessarily when you hit a bump, but more when driving along an uneven road at 20-30mph. Sounds as though something's about to drop off so was very surprised we didn't find something obvious!
Any suggestions to what it could be?
