Hi there, I have sourced uprated polyurethane bushes for the front 22mm type ARBs of Alfa Roemo 156/147.
My friend is a mill/lathe operater & can supply replacement S/S collars which can be fitted to the anti-roll-bar...... the standard collars often crack therefore allowing the arb to shift form side to side.
if you want more info read this thread
thanks, Pat.
Banned
Never seen a split bush on the ARBs, and not many folk on here speak of them,and at £40 I think 2 jubilee clips will do the job.
Discussion Starter #3 (Edited)
For £30 i'll supply the polyurethane bushes & two 40mm jubilee clips.
All costs included.
BTW: The split collars are designed as a replacement for the current collars which seems to be 'glued' to the arb & often crack at one of the joints allowing the arb to sway from side to side.
