1 - 20 of 26 Posts
I have a set of these in black (with alfa romeo in white on the outward face of the caliper) and i think they came off either a 156 or a 166
Now my problem is that im trying to fit them to my Series One Peugeot 106 Rallye, but i cant find any information on the discs that they use ie diameter, thickness, offset etc
Could one of you kind folks point me in the right direction please :)
Black with white isnt off a 156/147 or GT so pass, sorry.
Generally Brembos on these Alfas fitted 305 or 330mm discs
I dont have the specs for the 166, sorry
H
get brembo calipers and discs from a 406 coupe, they bolt straight on to the 106
Aye mate i know, but i got these for 40 notes from a scrap yard, i like a bit of a challenge and plus everyone does the 406 Brembo thing i want tio be different. oh and the alfa romeo will be staying on them :)
are they lug or radial mounted?
what space is the inside opening of the caliper, take 2 mm off that & thats the max width
they could be from a 166 which uses 310mm x 28mm discs .... iirc.
156 uses 305mm x 28mm or 330mm x 32mm
not a clue on how they are mounted bud, i didnt take them off (which riled me abit as i like to see how things are attached) there are two bolt holes on the caliper itself ? I'll have a measure between the pads and see :) Then i'll check if Peugeot have any discs of similar thickness :) although saying that the max diameter will only be 283mm
They will be lug mounted and probably off of a 166.
so 310x28 disc.
The only radial mounted calipers were red and on a GTA.
Unless you have found a set from a Crosswagon, which is unlikely.
the 2 mounting holes will be at least 100mm apart, possibly 130mm.
the peugeot will not match those diameters.
imho you need to get the 406 bits.
166 calipers, fit on a 310 x 28 disc. Mounting lug centres are 150mm, mounting bolts are m14. Just had some brackets made to fit some on the stratos rep using 285mm 164 discs.:thumbs:
thanks buddy :D these are the calipers ive got
I have the bolts that are used to mount them to the Alfa just need some kindly soul now to mount them to my car
OOh do they fit under 15's. Please say they do, ori 'll be getting the grinder out
Very VERY unlikely.
But it would depend on the size of disc you use and the design of your rims.
afaik, not a hope.....16" min
+ 10mm HUBCENTRIC spacers .... at least 10, could anything up to 20mm
i had 282mm discs on my old rover with 15 wheels.
if the wheel design is right they will fit. almost certainly with the fore mentioned hub centric spacers.
Discussion Starter #16
cheers lads for the help, i hope they do fit under 15's or i'll be gutted having just bought some 15's :( I'll do a trial fit when i get home, as ive to pull one side of the suspension to bits to sort out a knackered balljoint
using with 282 x 22 will be ok, 310 x 28 won't fit.
also using a caliper designed for 28mm disc is UNSAFE when used with a 22mm wide disc..... when the pads wear out the pistons may 'pop' out :eek:
Good point Sears re the pistons.
My calipers/disc combo fits nicely under a 15" rim. They won't fit under any 15" rim though,
Yep, the make and type of rim is critical if you want/need to keep a small rim.
AP make a 4-pot setup for 156/147 that will fit with 15" race rims with 295mm discs, but are unlikely to fit under 15" road rims.
The 305mm Brembo setup only just fits under 16" road rims and runs VERY close to the outer ballance weights.
1 - 20 of 26 Posts
