The triangular inner corner is a reflector. Carefully prise that off by way of the slot ( careful you don't break the thin plastic at the edge.
Underneath are three screws. Two are identical and the third has a plastic collar. Ignore the third. Undo the other two. The outer edge has a pin that engages into a recess in the bumper so that needs to be disengaged - wiggle the unit out towards the centre of the car until the unit is free. I suggest you don't undo all the wires without recording their position as some connectors can be interchangeable!
EDIT : In case you're wondering, the third screw adjusts the fog light aim.
