1 - 14 of 14 Posts
Just in the process of installing some fog lights on my S2 33.
It has the button installed inside.
Do these lights have a separate relay?
I see 2 free relay slots on the main relay board with the 4 connections installed already.
Hi Brit
There is a Foglight Relay (I17) shown on the 1.7 engined Sprints - from 1985 wiring diagram, so I think that there would be one on a 33 as well.
30 amp 4 pin should be quite sufficient I think.
2 x 55w halogen lamps. About 9 amps according to my calculation.
If you have a spares car, grab a switch for position 3 and a relay for position E, and the factory foglight plugs will become usable.:thumbs:
Beware that if you hang high-powered driving lights off them, a pin in a wiring loom junction plug near the brake booster will burn out and you'll have to bypass it.:p
Isn't #2 the foglight switch?
Which relay slot does this go to?
I have the 2 same free slots on my board.
I think the switches are: 1 = demister, 2 = rear foglights, and 3 = front foglights. I could have 2 and 3 round the wrong way (or maybe I deliberately swapped them years ago) but I can't be bothered to go find my owners manual. :p
I'm not sure which (if any) of the relays is for the rear foglights, but why does that help you? If you were prepared to lose your rear foglights, I guess you could swap the plugs between switches 2 and 3 and pinch a relay from somewhere to put in the 'E' position to get your front foglights going..
got a couple of new relays :)
I think I will use the de-mister button and swap that to the blank and use E on the relay board as you pointed out.
(De-mister is totally knackered so it has no use!)
After 2 hours fiddling with the wires and switches I finally found a relay position that worked for the front fog lights I installed.
Slot next to E. Possibly the de-mister switch. So I settled with that until I get a front fog light button.
Anyone??
The blank switch on the right(#3) had no live connections. Found some yellow wires from that totally melted next to the fuse box!! Was a right mess.
Also I tried the rear fog lights switch - nothing. Which relay slot is this?
Discussion Starter #14
I know my previous mechanic did some cowboy wiring to enable the main headlights to come on when the engine is running (by law-headlights on all the time).
It's quite a riddle there.
But now I can switch the front fog lights on or off regardless of the main headlights.:)
1 - 14 of 14 Posts
