My fog light switch for the front fogs doesn't light up. The one for the rears does.
Is there a bulb in there? Is it easy to replace it, or is it a centre console out job..??
Ta..!
It's an LED. It'll require some soldering skills to replace. ( Have you checked the supply wire for +12v? ).
No need to take the centre console out. Take the rev/speedometer out and push the whole switch cluster out from behind (assuming you don't have a special tool for this job). Maybe its just a bad connection/oxidation. If not, get a used one from "fleebay".
Phase 2 switches are either side of the hazard switch above the radio.
How do you reach the switch from behind the clocks, its miles away..:confused:
Only works for a phase 1 ( the switches were on the panel where your headlamp aim device is ).
