Are you trying to be funny, or trying to be obnoxious ?
The top parcel shelf cant be removed like that.
removing the rear seats, headrest etc, and you still cant remove it, as something is still preventing it from being removed.
First is the brake light assembly, and secondly something below where the sub woofer is.
And not the side trimming.
I'm not trying to be obnoxious, as I don't think I have been either offensive or repulsive. Sarcastic yes, obnoxious no!
However, it would help if you had said what you have tried so far. It'd save time.
The top section does come off.
Here's how.
First, remove the rear seat, but this is easy! Two Allen-key bolts hold tabs to the chassis; look under the front-bottom edge of the seat cushion. Remove those, and the cushion just lifts off.
Two more bolts secure tabs at the bottom of the seat upright. Undo these, and the upright pulls upwards and off; there are retaining tabs at the back of the seat that simply pull out from the metal upright behind the seat.
Once out, you'll find some round plastic clips holding the parcel shelf down. Remove these, then manoevre the parcel shelf out.
The seatbelts will be in the way a little, but no big deal.
OR
remove entire back seat, 6mm allen headed x 4
remove C pillar trim, X headed screws x2 then pull away from pillars
remove 4 'pop-in' plastic rivets
should lift up & outwards.... oh yeah remove 3rd brakelight connector
OR EVEN
Hi, I had this problem with my parcel shelf, if you drop the cover under parcel shelf in the boot check the stud fasteners that attach it to the beam the sub and amp sit on. Mine was a nut that had dropped off in the centre position (found it sitting on the top of the cover). It seems the sub can undo the fasteners!
(Borrowed from elsewhere in the site. Search is good)
Oh, can I have a cookie now too?
I assume a thank you would be out of the question.
