The wiring info gleaned from this group and alt.autos.alfa-romeo helped but wasn't quit correct.
My Bella is a Nov 2003 147 1.6TS Lusseo UK spec
( all directions from rear of car looking forward into car)
Reversing light on hatch is served by 2 wires, white/black is power,
purple/black is earth.
These join with wires from rear fog, hatch brake light and wiper into a wire loom that passes into the roof space via the rubber gator at the top of the hatch.
This combined loom passes to the R and down the R rear pillar to the boot space where it splits.
All the earth wires pass backwards to an earthing point situated on the boot lip bulkhead to the R of the hatch lock and behind the plastic boot lip cover which is held on with 4 clips,3 screws and 2 bolts also holding the luggage restraint rings.
The power leads in the wire loom pass forward under the rear seat back, under the rear seat on the R side of the car and under the floor carpet forward under the drivers seat.
The wiring loom can be easily displayed and a connection made to the
reversing light power lead ( white/black) under the rear seat base.
Fitting was simple. Removed the internal boot plastic molding( 3 screws,2 bolts ) and remove 3 bolts holding the bottom of the bumper to the bumper stays.
Clean internal surface of bumper with solvent ( I used petrol ) and allow to dry. Sensoe strip then stuck to internal surface with connector on R side ( drivers side )
In booy on R side is a rubber grommet through wich the connection wire can be passed to sensor connector. Electronic unit can be stuck with adhesive pad in R corner of boot under carpet.
Earth wire from unit can be connected to earthing point located on rear boot metal work to R of hatch lock. Will be hidden by plastic boot moulding. Positive wire led forward on R side, under rear seat back to wiring loom exposed when rear seat base pulled forward. Remove tape on wiring loom and locate Black/white wire and make connection.
All wire to wire or wire to plug connections were soldered and the sensor strip covered in waterproof tape.
System works well.
3 beeps on selecting reverese gear. Unit operational
3 slow beeps when 100 to 80 cms from object.
3 fast beeps from 50cms.
Continious tone from 30 cms.
Worked on metal gate, plastic bin and volunteer as well as the wifes KA.
Very pleased. Took just over an hour to fit.
Cool, my 147 workshop CD is more than 1½ years old. Quite odd they chose to run the wires on the opposite side than before :confused: At least I got the wire colour right :D Glad it worked though :cool:
-- hoygs
Always wondered about retro-fitting these things given that rear visibility isn't fantastic.
Would certainly be interested in how you get on Oldboy.
Kit came in the post today, looks easy enough, especially with all the instructions at the top of this post. Just got to work out how the bumper is held on now. Will keep you informed of progress.
I'd be very wary about retro fitting these. Cars with multiplex wiring (like the 147) do not take kindly with having extra loads 'tapped' in to the electrics without additional relays etc - at best, it can bring up false errors on the dash and at worse, malfunction components.
Multiplex is incredibly sensitive given the fact that when the ignition is off 10v is constantly supplied to most components. Only when the ignition is on is a further 12v supplied which then operates them. Therefore with only a 2v fluctuation between on and off so to speak, it makes tapping into looms very trickey indeed.
Thanks Alfa 147, I will bear your advice in mind and might consider fitting a relay.
It was ordered from http://www.carparkingsensordirect.com/ and cost £78.90 including vat and delivery by royal mail special delivery, recd in two days, well impressed with service.
When I get round to fitting it I will leave an update, might try and take some pictures as well as this might be helpful to others if successful.
