Still having non starting issues with my wife’s 2009 159ti 2.0jtdm!.
This is how the story goes.....
Car was stalling whilst in traffic and whilst slowing down.
Then one day it just refused to start at all!.
So..... I replaced the crank sensor with a brand new Bosch one..no change.
Couldn’t hear the in tank fuel pump priming so checked fuses and relays,all were good,so pulled out the pump,hooked it up to 12v,nothing!!.
Yeeeeah I thought there’s the problem.
Bought a brand new Bosch pump,stuck it in,put new connectors on the fuel lines,one way valves,new fuel lines,ignition on and off it went priming and bled it up to the brand new fuel filter.
Still won’t start?!!.
Stuck it on diagnostics and got (what you see in the video) back?.
Tried a new Bosch high pressure pump on it....no change!!.
Four brand new Bosch injectors....no change!!.
New Bosch fuel pressure sensor...no change!!.
New cam sensor....no change! .
New Bosch glow plugs and control module.....no change!.
New Bosch MAF....no change!
New injector leak off pipes and the plastic thingy that sits near the hp pump.....no change!
It’s also had a brand new Bosch hd battery,brand new egr valve,all new fuses and relays,every earth point has been ground back.
I even sent the ECU off for testing and that came back with no faults?.
The car WILL start with a little squirt of easy start,it will drive 100% perfect with zero smoke or drama.
As soon as it’s turned off.....it’s back to not starting!!!??? .
Now as you can see by the video footage of the multiscan the rail pressure exceeds the requirements for it to start briefly but then plummets.
There are no leaks anywhere,all connections are tight!!.
I’ve tried three different rail pressure sensors.....all read the same ??
I genuinely haven’t got a clue now??
A quick update on this car
I have put on new quick release fuel line connectors and fuel lines from the tank to filter-to high pressure pump.
I recently had a auto electrician on the car for a day and he diagnosed it as a dodgy starter motor that was sucking so many amps that the Ecu wasn’t firing the injectors hence the rail pressure being all over the place!.
So....had a brand new starter motor fitted,picked the car up to drive the 20 miles back home and as soon as it was boosting on the turbo on came the engine management light came on!.
6miles from home the car started stalling to the point where it ended up getting recovered home!.
Same symptoms as a turbo hose split or off,checked the next day on upper and lower hoses and they are perfect.
So now I’m back to square one!!.
This is a list of what’s been replaced (all new Bosch parts apart from egr valve)
In tank fuel pump
High pressure fuel pump
Four brand new injectors
Fuel rail
Fuel rail sensor
Fuel pressure regulator
Leak off pipes
All new quick release fuel pipeline connectors and fuel lines
Fuel filter
All brand new fuses and relays
Egr valve
Camshaft sensor
Crankshaft sensor
Brand new Bosch high amp battery
New blade fuses on the battery connector
All earths ground back to metal.
Engine turns over like the clappers!,but still on multiscan the rail pressure goes above and beyond the pressure needed to fire up,but then drops as fast as it goes up?.(see video)
There are no leaks anywhere!!.
Getting close to burning it now!!
Cannot work out how to post videos on here?,anybody help please?
In tank fuel pump
Fuel rail
Fuel rail sensor
Leak off pipes
Fuel filter
Egr valve
Camshaft sensor
Crankshaft sensor
