I've just got a pair of the silver Brembos from a Fiat Coupe, and would like to fit them to my 97 155 2.0 TS. I know that a lot of the suspension is the same as the Bravo, so I'm wondering if the hubs are the same. If so, I can then just get the caliper carriers from the Fiat and fit the brakes on with new discs. Unfortunately Fiat / Alfa say they are two different part numbers. Does anyone know if they are the same? I have 17" wheels, so that is the first problem solved. I think the master cylinder should be OK as I have the V6 brakes on mine (all late 2.0 16v 155's came with 284mm discs so I'm told). The Fiat discs will be 315mm.
The 3.0 GTV came with Brembo brakes. Perhaps these had the same hubs?
I've been thinking about the same brake conversion and had a discussion with "Seidici". He told me they do not fit at all. That is all I know. But if you try it anyway, please tell us if you make them fit the 155.
And about the GTV, they should have the same front suspension as the 155 and the Fiats so why not?
Thanks Jan,
An email is winging its way to him now!!!
