My left fender indicator is not working, but i am not getting the fast flashing indicating that something is wrong.
Also is there a bulb that i should replace or do i have to replace the entire indicator unit on the fender?
Any specifications / instructions on this will be helpful.
Thanks :thumbup:
I think that they are LED lights, so no bulbs to replace. I'd check the wiring first - just to be sure.
They are really easy to remove. If you open the bonnet and look down the side of the wing you can see the way they are mounted and release the clips to inspect them. They are LEDs so if they fail you have to replace the whole unit. I had to replace one on my G as it had cracked and moisture had got in.
