I've reviewed some of the threads on the horn issue but just wanted to clarify something - my horn works once, and then dies for about 10 minutes while it appears to "recharge". Then it works again, once. :confused: If this is an earthing issue, where should I earth from? Was toying with the idea of prising the front of the steering wheel to have a look but then remembered the airbag and thought better of it!
The horn is mounted on the front offside,in front of the wing liner.
If you can access it,they are secured by 1 bolt,as there are 2 horns on the mounting plate,they have push on spade connectors.
Get yourself a multimeter or electrical probe,check what power you have coming through.
It is easy if the bumper is removed.
