My 17 plate Mito has recently been acting up and I've been getting check engine light and loss of start/stop and DNA. The garage I took it to isn't an alfa garage so he's unsure of the codes and said he needed to send them off. Can anyone help? Its only done 28k and only pattern i can think of is when I'm at higher speed. Thanks in advance
Font Material property Paper product Paper Parallel
What type of engine is fitted to your Mito?
The problem is being caused by the Oil pump Pressure Regulator being faulty - Code P1541. It's an easy fix, just replace the faulty Regulator that is mounted on the side of the oil pump.
