1 - 2 of 2 Posts
Hi all can someone throw some light on this one off issue, going out for the day after all that flood water we went through the night before went to put my right foot down and engine system control failure appears and code reader is saying P0238, switched off and restarted engine and it drove fine and after 3or4 stop starts light has cleared and has'nt come on since i drive a 147 jtd 16v 2004 remapped about 2 years ago so dont think this is the problem the only thing i have noticed over the past few months when idle in traffic it feels a bit hesitant (lumpy) not sure if this is linked hope for some ideas would be good could be ringing roy beale alfa specialist cheers
Like youself if you have seen the thread I had in about fault codes then you would see that the fault code is Turbocharger Boost sensor A circuit high.
Just a thought as to what you have described, perhaps you should check the ir filter incase the passage ways are not getting the air it needs and a sensor is being thrown out.Also check that you are getting enough fuel as something is telling you that you are giving your engine a message and its telling you its not up to it.
1 - 2 of 2 Posts
