1 - 20 of 52 Posts
Hi Guys
This has been requested, so here goes.........
4-4-4-4 - no errors
1-2-1-1 - battery voltage
1-2-1-4 - engine temperatue sensor
1-2-1-6 - throttle valve sensor
1-2-2-1 - air flow meter
1-2-2-2 - idle actuator (opening)
1-2-2-3 - regulation of lambda probe
1-2-2-4 - heated lambda probe
1-2-2-5 - air temperature sensor
1-2-2-6 - electroinjectors (group 1)
1-2-3-1 - power ciruit (inside control unit)
1-2-3-2 - electroinjectors (group 2)
1-2-3-3 - idle actuator (closure)
1-2-3-5 - compressor inlets
1-2-3-6 - compressor command
1-2-4-3 - fuel pump relay
1-2-4-4 - vapour recovery solenoid valve
1-2-4-5 - timing variator relay (1.8 and 2.0 TS only)
1-2-5-1 - control unit EPROM
1-2-5-4 - throttle valve sensor (signal)
NB. This does not work on the 2.0 16v, please advise if you find it doesn't work on any others....thanks :)
wrinx :D
and a link showing how
http://www.youtube.com/watch?v=1Bq6k3zKa3I&feature=youtu.be
Discussion Starter · #2 ·
ive never had to use this test before so can you just take me through the procedure..cheers..
Turn the key to Marcia (ignition lights etc)
Fully depress (to the floor) the accelerator five times within five seconds and fully release.
The code should come up more or less straight away.
wrinx
wrinx said:
Hi Guys
4-4-4-4 - no errors
wrinx :D
hi guess what dont work on my v6 there a suprise.
wrinx said:
What year is your V6? It works on my 95 V6 :(
wrinx
1996 v6 i think this car is a wrongen i looked throw the old q and a and have found some stuff on this problem i am having with code hope it helps so i can drive the old girl soon i am paying for her and not getting to much fun *****. :rant: thanks for your hel great site ;)
Discussion Starter · #11 ·
wrinx
i try to do exacly what you said but did'nt seem to work :( when you say fully depress do you mean keep you foot to the floor or pump the accelerator five times! saying that i've seem to have a long bolt behind the gas pedal
If yours is a 16V then fault code diagnosis will not work. Its a pain and no one seems to know why, think you need an Alfa specialist with the right equipment.
Jack
Discussion Starter · #14 ·
Andy i think it was the 2 litre 16v i didn't work on not the 1.8 litre 16v , anybody verify this. :confused:
Discussion Starter · #16 ·
Can anybody tell me if the above is true or is it on all 16v :rolleyes:
Discussion Starter · #18 ·
Nope, doesn't work on my 1.8 either. I think (?) it will only work on the 1995-ish cars with a "Code" sticker on the window but could be wrong. The manual does describe a method for use on the 16v cars but I keep forgetting to dig it out :rolleyes:
wrinx
Discussion Starter · #19 ·
If you could find the info we would all be greatfull, or when you are out give the baby sitter something to do. ;) ;)
1 - 20 of 52 Posts
