Does anyone know where I can get a fan variator- mine's knacked and big connector into it has melted so I need that as well. Alfa Spider 916 Ph2
Part number is PA 6.6-GF30 or 52466964 - 12V but also need larger of two connectors which plugs into unit in port marked with + -.
Do you mean the unit that sits in the single fan shroud. I might have one.
Hi, not sure what you mean. This unit has an oval casing and four metal fins that protrude. It is (was) bolted into front bulkhead under the passenger side footwell.
Same part on a 156, a 147, and a GT I think? Lots of 156s being dismantled here; not sure if it's the same situation in England.
-Alex
-Alex
Got one now thanks. Found a breaker in Haslingden Lancs who is very good. Popped over in the snow (not the brightest of ideas) and picked one up.
