1 - 12 of 12 Posts
· Registered
My Brera failed it's first MOT today.
Failure: Leaking from steering rack. Had no idea, no visable leaks or moans or groans from my steering. It has been perfect.
And so my search begins to get the problem sorted :confused:
Hope I can get it fixed without paying a fortune :mad:
· Registered
Red! Back during the huge forum 'should it be red or green' debate, I was told my red fluid was fine so long as the steering was quiet. Which it has been, this MOT failure is the first bother I have had with the car.
· Registered
My 159 has red in it too, though I changed the mates Brera to green - and I had a PAS pump changed in 2009!
I will be putting green in the 159 shortly.
You will find the manual says G1/E (red) but the sticker under the bonnet G1/R (green)
· Registered
Discussion Starter · #6 ·
UPDATE:
Took the car to local trusted indie who said the rack would need replaced as it was leaking quite badly however he said as the only issue was the leak (steering is fine, not loose or making any noise), to try a bottle of 'Lucas Stop Leak' for power steering systems and get the underbody washed and take it for a retest.
Added half a bottle of this 'potion'. Within 10 miles the leak had stopped. Took the car to the MOT centre for its retest, and it passed within minutes. No leak found.
Now done 400 miles with no leaks or problems with the rack.
Sorted and through the MOT for a tenner!
· Registered
Its through the MOT - but it isnt sorted.
The Dexron was proved to be too thick as it was hence the G1/R reccomendation, putting that treacle in it is short term.
Get it sorted/ flushed out before winter when the gloopiness will cause more problems.
1 - 12 of 12 Posts
