i have a 2.0 ts 16v. i have a problem.
when i accelerate from 0 km/h, it appears to lose
power ( it kind of dies) then... whoop..then back to normal. It's only i hit the pedal to the metal. anybody who knows what's wrong?
I have another problem.
sometimes the gas tank makes a wierd noise.
it dissaperes if i turn the cover.??
could it be a blocked airing?
:confused:
Discussion Starter · #2 ·
check the plugs and leads first..the fuel tank has pressure valve on it you were hearing the valve letting off the excess pressure.
the plugs are new, and the lead is ok. But it is still doing it.
Were is the pressure valve?
the pressure valve is stuck up on top of the fuel tank....it is supposed to make that noise so dont panic.
