Right folks as above, mrs just phoned taking son to work and no nearside lights - either dip or main beam!
I am at work at the mo so will not get chance to look till tonight when it's dark so any thoughts on cause etc would be appreciated. I assume main beam and dip are seperate bulbs. Also the car is a facelift 2004 sportronic v6 and had xenons.
Await help !
Mark
I would check fuses first of course. Under the dash, fuse number 6 (7.5A). Since both have gone I assume it would be this one.
Athorwise there are another two next to coolant reservoir. Number 12 and 10. Both 15A. Separate for left and right light.
Cheers, but as typical Alfa got in this morning and everything worked fine, so I guess will need to check connections !
