Hi guys,
Ive been offered soem Evo R's 17". They were orignally fitted onto an XR3i!!!!!
I was thinking of havin if there going cheap enough. I just wanted to know if they would fit My 155 (1995)
Do any of you gusy know wether they will fit??
Regards Dom
Discussion Starter · #2 ·
You'll probably need the "Varibolt" thingys that Henry uses. Think he said you get them from Halfords.
Marlon
Fords are 4 x 108 PCD holes, unless they have 8 bolt holes in and one set are 4 x 100 PCD. If they are 4 x 100, then you do need varibolts to get them to fit. I have a spare set actually, but they look slightly scruffy, but would clean up. If they have a centre cap (which I think Evo R's do) they you would be fine.
Check the offset is right too as 155's require about a 35 mm offset to run right. Have a look at www.tyresave.co.uk as there is a wheel size translator on there which shows the offsets.
