Hello everyone,
I'm having trouble with my Alfa with error glow plug at startup..
I've changed all four glow plugs, changed battery, glow plug relay...still getting error...
Can someone helo me with this..I don't know what to do anymore..?
As you changed all the parts check for 12v out of relay and to the glow plugs when switching ignition on.
Also might be worth an extra earth from battery to engine.
Have you cleared the faults since changing the parts?
Discussion Starter · #3 · (Edited)
I've changed the relay 50A and error was deleted one day...tommorow error comes out again..i don't know what to check next?
All glow plugs are alright, but error still comes out..
Remove the gowplugs and reconnect the electrical connector.
Rest a baking tray on the engine and put the glowplugs on the tray. Make sure you have a good earth to the baking tray (maybe a jump lead) and turn the ignition on for about 5 seconds. Turn the ignition off and check the tips of the glowplugs, see which, if any, don't get hot.
Careful touching the plugs, they get bl00dy hot.
Good luck
Pub
Good luck
Pub
Thanks, but I already tested them, they work perfectly...I bought them new few months ago...
You need to check you actually have power out of the relay to plugs before going any further. Put a meter on the wiring and turn ignition on to make sure you got 12v going to them.
Discussion Starter · #7 ·
I found out the problem...it was bad wiring...i checked glow plugs from relay with multimeter one didn't get any power. When i shaked the connector of glow plug the error dissapeared.
Thanks everyone for your solutions :)
