Hello Alfisti,
I have been trying to fix the "Excessive Radiator Fluid Temperature" error for a long time. There are many threads on the forum, and I tried almost everything, but the problem remained. Many people pointed out it is an electrical problem related to the stability of the voltage. I have replaced the battery three months ago (the new battery is Exide 77AH 760A), radiator fluid sensor, the starter was serviced a year ago, ECU software updated (pre-heating interval of glowplugs extended), new EGR valve installed, injectors checked, as well electrical instalation. Everything seems fine.
Let me explain how the problem manifests. After inserting the key fob, I wait for glow plugs to heat. When I press the start button, the engine starts with the ignition, that it starts to shake, the error pops up on the screen and the engine sometimes starts sometimes turns off. Someone recorded the same problem. Here is the youtube link:
The problem usually occurs in the morning during the cold start. The second attempt of ignition is always fine. The same thing could also happen later in the day. I have noticed that extreme cold or extreme heat increases the chances for the problem to occur. My garage told me it is a common problem with Fiat/Alfa Romeo vehicles. They believe that the ECU gets confused if the voltage during ignition is lower than required. If the battery is fully charged, the problem really occurs. Unfortunately, during hop-in-hop-off city driving the alternator does not have a chance to fully charge the battery.
Any suggestions or ideas?
Thanks,
Aleksandar
Thanks,
Aleksandar
