Error code help needed P1062
4.5K views 6 replies 4 participants last post by  Ed_
#1 ·
I've got P1062 coming up, using Veepeak OBDII reader and Torque Pro app, which I bought from a recommendation from this board. Only thing is, P1062 is an unknown code on Torque and I can't find anything exact from googling. The vehicle message is "Start/Stop is unavailable. Check engine" (I didn't know I had start/stop!) It's a 2012 Giulietta 1.4 multiair. Anyone any ideas?
Ed
#5 ·
I believe jetronic77 means the solenoid coils in the MA not the ignition coils. Compare the resistance for cyl 2 against one of the others. The doc below lists all the troubleshooting steps for that code.
#6 · (Edited)
May I suggest to try cleaning the connections to the MA solenoids first, if that fails then try replacing/cleaning the MultiAir Oil Strainer. These suggestions may or may not solve your problem and you may be up for a replacement MA unit, but should be done before going any further.
