As per title,now ready in stock,equal length downpipes in stainless for ph3 engined 147 GTA, 156 2,5 and 3.2GTA, GTV 3 or 3.2
Straight swapare these a straight swap or do they have to be coupled with gtv manifolds?
likewiseI want some but I'm skint![]()
I think the only change in noise would be down to velocity of gases escaping, might attenuate the sound a little making it less boomy I doubt it would be louder though.likewise
need to hear them as well really before going down that route - must be getting old!
Gus any chance of getting a video clip etc posted?
Don't see why not - assuming you're running standard downpipes, fitment wouldn't be an issue. If your not running standard downpipes, then you've no need for themi fancy some but need to work out if they are compatible with my manifolds first.
autodelta ones. pabloss has got the same ones and he reckons they aint do-able, ill have to double check tho.Which manifolds do you have?
upload viddrove back from gus 's after fitting downpipes and remap and the car feels alot more responsive, u can certainly hear a raspier engine note when i first jumped in and listened to with the throttle, car pulls alot smoother and faster through the revs and with the remap the rev limiter increases which used to be a pain , the difference was quite apparent but after using alot of fuel home i will probably get used to it soon and it feel like normal.
definately a worthwile upgrade for the money![]()
