1 - 20 of 42 Posts
It will be a bit slow to start with as it is limited to 512kb upload speed.
Discussion Starter · #9 ·
installed on a win8 machine but just get a white screen when trying to open on any device :(
Eh, need quite a bit more info than that!
Mine is installed on Win8.1 works fine.
Did you copy the dll file and log file to the correct place.
Also you will find windows might need the folders security setting need changing.
Discussion Starter · #11 ·
Keep seeding please, need to keep it there for a while to allow others to downloadd it.
Took me 2 weeks do find a recent eper.
The ones i found are all hosted on pay per download sites, which i bloody hate. :mad:
Thanks :thumbs:
Awesome.. it works.. I had to change the security on the folder to allow all.. took a bit of fiddling....
Only thing is it doesn't work in English.. only Italian.
When you open ePer and click to change language to English, in your browser address bar highlight and delete '&SAVE_PARAM=LANGUAGE'.
What you'll be left with should be 'http://127.0.0.1:7080/navi?KEY=STARTUP&LANGUAGE=3&GUI_LANG=3'
Should work. There's probably a more permanent way around it if anyone else knows.
That worked perfectly. thanks. :)
Discussion Starter · #16 · (Edited)
There is a dropdown menu, top right that allows you to change language.
There is, but for some reason when I select another language the screen stays blank.
I'm guessing that is the problem Alfa156Melb had too.
Changing the URL is a quick way to get around that I found.
Discussion Starter · #19 ·
What browser are you using.
I find it only works properly in IE
Chrome - I havent tested it in IE yet..
And yep, I used the menu drop down, just got a blank screen as said above.
1 - 20 of 42 Posts
