1 - 18 of 18 Posts
Hi All,
Does anyone know where I can find a fully working version of eper ?
I have accessed eper through many web links but can not find one that works properly.
The problem is the sections with multiple pages e.g. the Alfa GT rear suspension section has 4 pages. The first page is the default but if I select the 2nd, 3rd or 4th then I end up back at the start of eper.
Is this problem the same for you when you use it ?
It tends not to work properly on anything other than IE or Firefox (I assume thats something to do with the HTML used.) It also depends which version you use. The one I have on CD is something like ver 16, whereas the one from the FIAT forum is newer and thus works better.
I tried using the links from the various replies below without improvement.
My browser is Safari (Apple Mac). I will try using a PC and see if it works better. I am guessing it is a general bug.
Thanks for the replies.
If someone would like to try the page linked below, then scroll down, then try and select image 2, 3 or 4 and let me know what happens. That should prove it once and for all.
Works fine.
No problems there.
Edit: I'm using a PC running Vista & IE7. XP & IE7 works fine too.
I tried Firefox a few years ago and it always had problems, so stopped using Firefox.
It works fine with internet explorer, but if I try it with firefox or safari it goes back to the homepage.
Discussion Starter · #12 ·
Hi all,
I finally tried this using Explorer and it worked fine. Guess I will just avoid using my Mac when looking for parts.
It works fine for me on Safari.
I would start by clearing all of your temporary internet files and cookies - just click on 'reset safari', and leave every box ticked other than the passwords box.
I couldn't get it to work on Safari (Version 4 Developer Preview 4526.11.2) and on Firefox 3, all on OS X 10.4.11. It always goes to the starting page when I try to click on the additional pictures.
Everything works fine in IE in a Virtualbox virtual machine, although the dinosaur that is IE 5.2.3 for Mac seems to get stuck when running on an Intel Mac.
Utilizing the circuit designs perfected for recently introduced Quad
Operational Amplifiers, these dual operational amplifiers feature 1) low
power drain, 2) a common mode input voltage range extending to
ground/VEE, 3) single supply or split supply operation and 4) pinouts
compatible with the popular MC1558 dual operational amplifier. The LM158
series is equivalent to one–half of an LM124.
These amplifiers have several distinct advantages over standard
operational amplifier types in single supply applications. They can operate at
supply voltages as low as 3.0 V or as high as 32 V, with quiescent currents
about one–fifth of those associated with the MC1741 (on a per amplifier
basis). The common mode input range includes the negative supply, thereby
eliminating the necessity for external biasing components in many
applications. The output voltage range also includes the negative power
supply voltage.
• Short Circuit Protected Outputs
• True Differential Input Stage
• Single Supply Operation: 3.0 V to 32 V
• Low Input Bias Currents
• Internally Compensated
• Common Mode Range Extends to Negative Supply
• Single and Split Supply Operation
• Similar Performance to the Popular MC1558
• ESD Clamps on the Inputs Increase Ruggedness of the Device without
Affecting Operation
From Electronic Components including Integrated Circuits, Semiconductors, Capacitors from Hqew.net
WTF ??? :confused:
Oh, and does anyone know how to get rid of the irritating adverts towards the right of the screen in ePer?
Reported the spammer earlier - no idea about the ads on ePer though, I have a copy on my PC (shh) , obviously no good for current prices, but a good source of part numbers...
1 - 18 of 18 Posts
