1 - 9 of 9 Posts
Hi Guys,
My radio has been locked, I have the 4 dashes on screen. I have tried what it says in the manual with no joy. I have noticed however the stereo is permanent live and not switched.
Are there any other methods I could try to reset the radio to CODE.
Jason
The permanent live is correct, but it will turn itself off after 20-minutes if the ignition is off.
If it is locked you need to have the radio turned on for an hour (which means the ignition on too, ie driving), you will then be able to input the code.
What have you tried?
well you need to find out what the code is now and you're good to go :)
By the way you won' find it in the manual unless somebody wrote it down there...it's on a separate sheet from what I know...+there's also a thread around here where you give the unit's serial numbers and somebody gives you the correct code in case you've lost it or don't know it :)
L
if you can remove the radio connect it to a battery for 1 hour +, when it asks for the codes then press the required buttons, if the code is 1234 then press buttons 1234 , it should then work.
1 - 9 of 9 Posts
