Hi all, due to the fact that my crankshaft is dead in my 2001 2.0 TS 147, I need a replacement engine.
I found a '98 2.0 TS CF2 engine, is this a straight swap, as i only need the block and the head ? The ECU and all the manifolds, injectors, auxiliaries(alternator, starter) can be moved from the CF3 engine as they are OK.
What would be the issues with this swap ?
